Cold Start Valve
Cold Start Valve
Is it possible, or worth trying, to remove and clean the cold start valve, similar to how you can clean the ISV? I've got a low idle when cold, and this is one thing I need to check.
The MFTS has been replaced, throttle control switch has been replaced, and the ISV has been cleaned out. Not sure what else to check. Basically I'm getting about 750 rpm during idle until it's warm.
Thanks.
Bill Graham
Thanks.
Bill Graham
Re: Cold Start Valve
Check your ISV temp sensor. It will cause what you are describing if the connection is bad or the switch has gone bad. Mine did on my 5000CSTQ, not sure if your 200QT 20 v has one though...
-Aaron
-Aaron
Thanks. I know where the multi-function temp sensor because I've replaced that. I know where the ISV is, but I'm not familiar with the the ISV temp sensor. Can you point me in direction of where it would be or a part number?
Thanks for your help.
The cold start valve just helps the car start when it is cold (as you might guess from its name). Once the car starts and you release the key, the cold start valve's job is done. It is not related to your idle issue.
Thanks. I'm learning that.
Wondered if it's not a temp sensor issue, but I'm not sure which. I may be wrong, but doesn't it have 3 temp related sensors? Sorry I don't know more. I'm still trying to learn this car.
I forgot to say ...
One time this winter:
It was really cold, and it idled at 750+/-. This was the morning after an ice storm and I let it run longer than usual to thaw out and avoid scraping. Well, I didn't tap the pedal, it never raised it's rpm's, and evidently didn't recharge the battery after cranking. When I got back to the car, it was not running, and the battery was dead.
I usually monitor the car more closely when it's warming up, so it's never had a chance to do this before.
I should also state that I can not find any vacuum leaks. I don't have access to a "smoke" machine however.
Thanks.
Thanks.
Here it is ...
This picture is from SJM site.Idle temp sensor is the one you are looking for.Click on the picture and see how to test it.
<a href="http://www.sjmautotechnik.com/10vcoolt.html">
<img src="http://astro.uchicago.edu/~mzm/personal/hobby/gif/tempsw2.jpg"></a>
Zhaoming
Zhaoming
big_anthoiny
10-25-2007 10:17 AM
diamond8990
11-18-2002 02:56 PM
