crank pulley?
Old Mar 4, 2004 | 03:50 PM
mofologic's Avatar
Default crank pulley?
is it possible to replace the timing belt (and only the timing belt) without removing the cranksahft pulley? i.e. - slip the new belt over the pulley. can't really tell from pics i have been able to find online. i will be doing the repair in a less than ideal location (too cheap to pay for a tow) and want this to be as painless as possible.
Old Mar 4, 2004 | 04:24 PM
cuatrokoop's Avatar
Default No, pulley gets removed. Belt interferes with the pump (pump has a shroud to protect the bottom
portion of the pulley/belt).
Old Mar 4, 2004 | 04:27 PM
quattro920's Avatar
Default Re: crank pulley?
If i remember correctly.... it's impossible, because without removing the crank pulley it's impossible to take of the lower timing belt cover. I am not too sure though, since my last timing belt job on the now RIP 5ks was done like 3 years ago...
On a side note, I don't know what you mean by "a less than ideal location," but I hope you are not fixing your car say on the shoulder of a freeway. I saw a nasty accident with some guy changing a flat on the shoulder of a pretty busy freeway. Not pretty at all. Be safe.
Hope that helps anyways,
Wilson.
Old Mar 4, 2004 | 05:32 PM
cuatrokoop's Avatar
Default No, you can get both covers off w/out pulling the pulley.
It has to do with the oil pump design. See my other post ;-)
Old Mar 4, 2004 | 06:36 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Where are you?
Old Mar 4, 2004 | 07:06 PM
RussB's Avatar
Default Face it: It's a pain
Since you're gonna have the front of the engine exposed, and this requires a fair amount of labor, this is a good time to replace everything there that's questionable: certainly water pump and idler pulley/bearing. Maybe crank and cam seals. To do less is poor economy.
Somehow, do this job in a clean, dry (and safe!) location.
Old Mar 4, 2004 | 10:36 PM
tonyj's Avatar
Depends on how good a mechanic you are and if you have the tools.
I did one with a friend a couple of years ago in an afternoon on a side street in Minneapolis where he lost his belt.
Summer weather helps a lot. Beer too.
discocontented
A4 (B7 Platform) Discussion
Aug 13, 2016 01:13 AM
fourks
Sep 19, 2012 12:50 PM
audia4on19s
Oct 27, 2005 12:01 PM
delmedina
9
Oct 27, 2005 08:13 AM
Vodka G
May 3, 2005 08:49 PM
