Front Brake Hose for 91 V8 with G60 Calipers
Do you know where is the good source to purchase front brake hose for 91 V8 with G60 conversion? I called Rod at Parts Connection and he was saying I need to look to see if the conversion is 100/200 or S4? This conversion was done by previous owner. Any ideas?
Re: Front Brake Hose for 91 V8 with G60 Calipers
They are different lengths based on how the bracketry works, I believe the 200 is female to male, the S4 is female to female. The S4 uses the shorter IMS. You need to pull the wheel off and measure the soft line, and ck to see if there is a short hard line that goes from the bracket into the caliper itself. If it has that hard line from the bracket then you need a female/female line (10x1.00 bubble flair). If you have the line going directly into the caliper(ala 5000/200), then you need a female to male and it should be a longer line.
HTH
Scott Justusson
QSHIPQ Performance Tuning
HTH
Scott Justusson
Evol
Audi 100 / A6 (C4 Platform)
11-24-2005 08:42 AM
UseTheS4ce
04-16-2005 11:46 AM
