help me find out whats wrong with my audi
hi.
i have an quite annoying problem with my audi.
the problem is:
when im trying to start it its hard to start.
and when it starts, and gets warm it will not idle and most of the power i gone.
the car is an 1989 audi 100 (5000 for you guys) 2,3e fwd non turbo.
i had one main suspect : the idle stabilisator
but ive changed it with one from an simular car that runs well, and the problem is still there.
anyone have any idea what migth be wrong?
please exuse my english
im from norway and my english isent perfekt.
BTW if any of you need etka images i can help you
just send me an mail to: te.strom@gmail.com
the problem is:
'89 models became 100 here like in Europe to ditch the bad rep of the 5k in N.A.
Being a non-turbo I am not that familiar. Pull codes if you can.
WUR? (Warm Up Regulator)
Fuel pressure? Pump issues? Leaky fuel lines?
Check crank ref and RPM sensors.
Have you done a full tune up with plugs/wires/cap/rotor, fuel and air filters? DO IT! Weak spark could be it as well.
Re: "Pull codes, check for boost leaks." I'll bet aerohr 200 bucks there are no boost leaks :p
Kinda of hard to get a boost leak from a non-turbo car.
"1989 audi 100 (5000 for you guys) 2,3e fwd non turbo"
ok a small update
ive changed the plugs, plug wieres and the distributor cap.
now the car runs great almost lost my licence
but it still wont idle. when it warm.
hmm you guys told me to pull codes,
are you talking about diagnostics codes?? if so i cant since my audi dont have an diagnostics system.
and if you ment engine code, its an nf engine.
with an catalysator.
but now there has been a change, now it idles when its cold, it is realy hard to start, and when its warm i have to uce start gas to start it.
about the rpm sensor, if that sensor is broken my
rpm gauge in the dashboard whoud not work rigth?
about the ideling problem:
when i let it go under 1500-2000 rpm it just dies just like ive turned the ignishion off.
so what do you guys think?
im from norway and my english is not perfekt.
CvTech
21
03-22-2005 01:20 PM
audimom
10-01-2003 01:37 PM
audionly
05-20-2003 10:42 AM
