interference engine?
Old Nov 18, 2001 | 12:21 AM
thermonuclear's Avatar
Default interference engine?
I was reading about what could happen when a timing belt fails on interference engines and I was curious if mine had an interference engine or not? thanks
Old Nov 18, 2001 | 09:33 PM
fredmau's Avatar
New Member
Default Re: interference engine?
The diesel 5000 engines were definately 'crashers' as we called them. I don't believe the (non-turbo) gas engines were - At least, I remember some of them coming into our shop with broken timing belts but without bent valves etc, all we had to do was replace the belt and everything else was fine.
Whether this was by design, or whether those instances were just sheer luck on the part of the owners, I don't recall.
Old Nov 19, 2001 | 07:02 AM
SteveAngry's Avatar
Default Correct...
the N/A Inline 5 was labeled a non interference engine from the factory...
However, there has been some debate on the Qlist that at high speeds/rpm's there could be some valve train damage on these engines. Personally, I've seen 2 N/A type 44 cars with broken timing belts and all they needed was a timing belt job and they were good to go. No valve train damage...
The turbo engined I5, the 20 valve I5 and the V8 are all interference engines of course...
Steve
Michigan
Twilight Blindness
Audi allroad
May 8, 2018 11:09 PM
Mountian_A4
29
Jul 8, 2005 11:55 AM
RedBelliedJet
May 4, 2003 09:20 PM
stevenmurray
Mar 8, 2003 08:44 PM
xjrpilot
Oct 8, 2001 10:23 AM
