K26 Turbo Question
What is the max psi or bar that the K26 Turbo can put out?
I'm thinking of putting a variable boost valve for my waste gate. I'm also thinking of routing my cold start injector into a newly drilled hole just next to the throttle position variable resistor switch. Then I was thinking of putting a solid state switching transistor and a 555 timer chip electrical device to run this cold start injector. It would turn on during full throttle and it would be pulsed just off of full throttle if needed. Of course I'll be figuring out what is needed in terms of pulsing when I get it all configured.
I now have an Air/Fuel meter on my dash which shows the o2 sensor output. I'd like to get at least 2.2bar going (1.2bar in all reality)
Any thoughts?
Thanks,
Alex
