Mounting rally foglights to 200 bumper?
Old Nov 13, 2007 | 12:42 PM
SlickDizzy's Avatar
Default Mounting rally foglights to 200 bumper?
I've got a sweet set of 6" round Bosch Rallye fog lights that I want to mount on the front bumper of my '90 200tq. I'm wondering what the best way to mount these would be - has anyone done this before? The lights are the usual mounting style (nut & bolt hanging vertically below the light).
Any help is much appreciated.
Old Nov 13, 2007 | 12:48 PM
boxerfan's Avatar
Default Check clearance and position. Mark and drill holes. Bolt tightly
Katman has mounted many a light like that. Frank.... the floor is yours...
Old Nov 13, 2007 | 12:56 PM
SlickDizzy's Avatar
Default Re: Check clearance and position. Mark and drill holes. Bolt tightly
Right, but how do I get my arm inside the bumper to thread on the nuts? That's my main concern.
Old Nov 13, 2007 | 01:48 PM
Kneale Brownson's Avatar
Tech Guru
Easy--two 8mm recessed hex head bolts, take out the blinker lights and pull out on the plastic bumper cover at the wheelwells. Whole assembly slides forward then.
If you're doing this at ground level, a low bench can help, especially with reinstallation.
Old Nov 13, 2007 | 02:19 PM
vwfreak's Avatar
Member
Default some advice
I found, on my 4K, that mounting the lights THROUGH the bumper cover caused them to shimmy while driving, so I cut out the area the base of the light contacts so the light bolts directly to the rebar and they are much much more stable.
Old Nov 14, 2007 | 09:00 AM
Katman's Avatar
Default Rally Lights mounting
I'm not sure what I did would work on a 5K..
<img src="http://www.frankdekat.com/pics/urq_hella1.jpg">
I wanted something that could take a lot of lights, but be easily installed and removed. I don't want to leave the lights on the car all the time, and didn't want to do any un-reversable changes. (No drilling the bumper).
So.. I made an angle-iron bar that the lights mount onto. Then the angle-iron bar has two tabs welded to it (appearing just above and to the outside of the parking lights) that mount under the bumper mounting bolts.
I've turned the bumper mounting bolts into studs, to make mounting the light bar easier.
The bumper is also missing it's cover, as I didn't want to mess it up. Besides, I didn't think that the light bar would be mounted firmly enough if it had a plastic 'cushion' between it and the bumper proper.
Old Nov 14, 2007 | 11:05 AM
smcg3's Avatar
Member
I had some hella 500's on my 5k wagon and I noticed it helped stability to have a little metal strip screwed into the back of the housing and then run behind the light and screw into the one of the slats on the grill. Helped with stability and maintaining proper aiming. You might not need that if you have meaty enough bolts, I guess.
cardinalfan
11
May 2, 2023 01:55 PM
RallyAudi
14
Apr 14, 2008 06:59 AM
RallyAudi
30
Mar 22, 2007 09:47 AM
DDMan
9
Feb 26, 2006 04:07 AM
Neutronian
Aug 23, 2005 05:11 AM
