Need help with 87 Audi 5000 S Quattro NF, not running right. LONG
#22
Any/all of it if the part numbers match
IME, the differential pressure regulator (the black one at the end) can be a problem, but usually that fails the voltage test if it's bad. The fuel pressure regulator (external) is good unless you can pull air thru the port. The flap position sensor in the side of the FD rarely fails.
When I pick up CIS cars (CGT x 4) and need to do field repairs to get them running, I skip diagnostics and swap the whole unit with a known good I have just for that purpose. Other than the DPR, it's usually just easier/cleaner/faster to swap the whole unit. YEMV
HTH
Scott J
HTH
Scott J
#25
Have you measured the voltages at the O2 sensor?
It is easy to get to and should be easy to see if it as failed. When I have seen failed o2 sensors they tend to give a constant voltage reading. They should give a constantly changing voltage reading.
A shot O2 sensor will make for very poor running and rotten milage. The ECU will be running in an open loop mode.
coupe d'mike
06-21-2005 01:02 PM
FFFR
04-26-2005 02:16 PM
brent4kQuattro
10-01-2004 07:09 PM
Me_and_my_GT
11-14-2003 05:33 PM
