Speedometer sensor testing 5000 QT
Old Dec 1, 2009 | 10:10 PM
Supradjza80's Avatar
Default Speedometer sensor testing 5000 QT
Hey guys,
I purchased my 87 turbo quattro 5000 with an inoperative speedo. After using the bentley I have determined that it is either the speedo sensor or the IC that is the problem. I have tested my speedo sensor and show that I get no pulsing 8V's from pins 2-3 when 12v is applied across 1-3 and the sensor is spun slowly clockwise. Due to this I have ordered replacements from force 5 and received two new sensors, both sensor also produce no pulsing 8V signal when doing the above test procedure.
Due to this I am lead to beleive my test system may be flawed or I am very unlucky and have 3 bad sensors. Has anybody done this test before and had trouble using a DMM to run the pulsing test? I think my meter responds fast enough that the test should be accurate but want to make sure I am not doing something incorrectly.
I am contemplating bringing the sensors to an electronics place to have someone use an Osciloscope on the sensor to be sure that they are all bad.
Thanks,
Dave
Old Dec 2, 2009 | 04:35 AM
5000CDQturbo's Avatar
welcome Dave to the forum !!
Inoperative Speedo is usually a cluster problem. I'm sorry I couldn't be of more help . superdave
Old Dec 2, 2009 | 06:31 AM
hdmyers's Avatar
my speedo is intermittent. yanking IC tonite to solder things up and make right.
Old Dec 2, 2009 | 07:55 AM
Thanks for the response and the welcome, I understand that clusters are a problem but I have never tested any of my 3 speedo sensors and had them pass the Bentley test. Has anyone done it with a DMM and had the test work? Or do I need an Oscilloscope to see the pulses?
Old Dec 2, 2009 | 12:28 PM
hdmyers's Avatar
i thought that you just measure impedance on the suckers to see if they are good or not.
Old Dec 2, 2009 | 02:55 PM
Well the manual says to test for voltage while spinning it slowly.
Dave
Old Dec 4, 2009 | 07:42 AM
hdmyers's Avatar
I can take a look. I can't get my fricken unit unbolted from my car. (one of the hex's mangled by my lack of patience!). Would be kewl to test regardless. I'll let you know.
Old Dec 4, 2009 | 11:18 PM
ahh I see, you have a 200 which has a completely different sensor from a 5000. Thanks for the effort though.
hardipk5
17
Nov 24, 2015 03:42 AM
urojohn
S4 (B8 Platform) Discussion
Nov 1, 2015 04:02 PM
Clarence Willie Mays
Sep 9, 2015 09:44 AM
S4intheOC
Sep 8, 2015 12:12 AM
C6Silver
Q7 MK 1 Discussion
Sep 1, 2015 08:46 PM
