Transmission
Apparently you still have doubts........
Check the vehicle data sticker in the trunk (probably on the inside of the lid). Look for eng.code/trans.code you should see WU and RDN or RDG,RDE,RDU,RDX). These are the 3 speed auto tranny (type 087) code letters.
Then check the tranny on the drivers side, on a flat surface very close to where the speedo cable enters into the housing, you should see a stamped tranny ID #, and the beginning should be RDN, or RDG, RDE....
If you don't see the same code letters as the sticker in the trunk then somewhere, sometime, a tranny swap was made with a slightly differing version. And who knows, if the code letters on the tranny is CDT, then someone threw in a 4 speed (it will bolt right up).
If the code letters indicate a 3 speed, you may want to have a tranny shop check it out, what you may be feeling is a slipping band or clutch, gear, etc.
in2audi
10-11-2003 01:09 PM
Max'sCoupeGT
15
01-21-2003 06:54 PM
