Ugh... V8 drivability issues are killing me!
3.6 V8 w/ manual trans, 034 flywheel, otherwise stock....
Here's the issue: Hesitation/poor acceleration, occasional jerkiness from a standing start (very noticeable), recently started having an occasionally bouncy idle when you let off the gas to stop(at a stop sign, etc). It will bounce a few times(200-800rpm), then self-correct and remain steady. The hesitation really feels like a timing issue to me, but I wonder how the idle issue would be related. Also, the car starts great everytime, hot or cold, any conditions, and idles great, revs great while parked, always returns to stable idle without issue. I don't have any gas mileage info, because I haven't been able to get the car running well enough to drive for any amount of time. Here's what I've already done...
New: O2 sensor, caps and rotors
Tested good per Bentley: IAT sensor, MAF sensor, G62 coolant temp sensor (in PS head), ISV, hall sender, plug wire resistance... also checked and cleaned all connections at these sensors.
Tried spraying WD40 on injector seals/elsewhere to find vacuum leaks, found none. TPS clicks when accelerator is depressed, I've cleaned the connections in the boot(there was some corrosion), but it didn't help. I have heard of a TPS that would click as it's supposed to, but still not function correctly. Does this sound reasonable?
Any other ideas? I'm getting really frustrated with this!
Re: Ugh... V8 drivability issues are killing me!
Are you sure it's a engine managment problem and not elsewhere in the car.. like say the Fuel pump pressure?
I'm guessing the car is a converted one and on the manual cars there is a solonoid that keeps the throddle plates from closing (suddenly) which would give you the idle bounce issue.
If the ECU says "no codes" then I wouldn't be looking at the electronics anymore, I would look at things that are mechanical in nature.
HTH.
-Scott
HTH.
-Scott
