What size is crankshaft nut,
Tools
You must lock the pully first. Then you need a 3/4 socket and a 3 or 4 ft handle. It will be easy then. Otherwise impossible. The pully has a rubber section and will just flex if not locked. My friend made one for me from section of pipe and an iron bar.
For the pulley stack/vibration damper? 27mm iirc...
And to break it off you can use a solid extension pipe and wedge the bar against the ground. Then use the starter to break it free. Works beautifully every time.
To put it back on you need a holder.
CincyQuattro
12-22-2007 09:52 AM
Kingttr
11-19-2007 04:08 AM
ITALSKIER
05-28-2005 04:21 PM
T-28-Quattro de VT
07-15-2004 08:53 AM
John P. (TT 225)
25
01-27-2004 02:21 PM
