1993 Audi 90 brake light question. Just need a quick answer!
Have a 1993 Audi 90 (non quattro) and whenever I would come to a stop the car would make a weird noise like a buzzing sound and then sound like the rotors were skipping. Took to mechanic and he said its your rotors that were rusty and need to be replaced so we replaced rotors and pads. Now problem is still there after we replaced rotors and pads. Was told maybe its the brake booster. How do I know if its bad? Now here's my main question. Was in the fuse box and saw that there is a fuse for the ABS. Took the fuse out and the problem isnt there any more. Car and brakes work perfectly with no buzzing or skipping. But when I took the fuse out the orange anti-lock off light came on in the dash board. Can I disconnect this light inside the instrument cluster? How do I do this? If I can just get the light to go out for now until I get it fixed would be great. Thanks so much and have a Merry Christmas to all!
Re: 1993 Audi 90 brake light question. Just need a quick answer!
you need to take out your instrument cluster, and then pull out the bulb for the ABS system.
first, unscrew the two screws (each located under the wheel). then, unscrew the two screws that hold the instrument cluster attached to the console. Then, slowly pull out the cluster but make sure that you disconnect the three harnesses and another wire attached to the cluster (forgot what it was for), and then take out the bulb.
AwdiA4
01-20-2005 05:42 AM
Sujan
10-12-2004 02:26 PM
loder
07-02-2001 06:30 PM
