20vt: Not running right, codes finally appeared.
I was driving today and my check engine light came on for a second, so when I got home, I retrieved the codes:
2111: Engine Speed Sensor
2224: Over-boost situation
2432: Oxygen Sensor
I don't know why the engine speed sensor code is coming up. If the sensor wasn't working, the engine wouldn't even start. But it starts, so I don't know what's up there.
The overboost one has got me confused too. I'll double check the wastegate solenoid and make sure it works right.
As for the Oxygen sensor one, I took the O2 sensor out of my 80 and put it on the new engine. I still have the one I took off the 3B, and might try swapping them again. My question is, would the O2 sensor cause a problem like the one I described above? I've got a few more things I want to try, but let me know what you know. Thanks.
1. You have a leak in the turbo exit hose. This is the funky hose that also leads to your bypass valve and to your crossover pipe/intercooler. I know you don't have an intercooler, but you should know which hose I'm talking about. Check all other vacuum/pressure lines as well. Do you have a bypass valve? Does it work?
2. You don't have a good vacuum connection between the back of the manifold and your ECU. Perhaps the hose blew off (common), or the line crimped while you were messing with the ECU.
3. It could be a poor electrical connection at the MAF.
I think one of the first two are most likely.
Good luck!
At the moment, I am waiting for the exhaust to cool down so I can swap the O2 sensor back out with the one that came in the engine (don't know what I was thinking).
I will double check the turbo exit hose. The end was cut off when I got it so there is currently a pipe stuck way up inside with a hose clamp. I will likely add another hose clamp. There is a good chance I am losing air at higher RPM/Boost levels, causing my loss of power due to wrong fuel mixture/loss of boost. Thanks.
