A6'er here need your help | I picked up a 1990 90 quattro - - - >>>
The drivers side window and sunroof work the first day then it all stop working | can't find any fuse or relay for the windows or sunroof | I checked the Bently manual but can't find any info |
I searched the previous post - but reached the dead end. Can someone please advise where and what to look for?
Thanks and regards.
Joe Avant A6
Thanks and regards.
Joe Avant A6
Well, a fuse or relay would most likely affect all 4 windows.
Check the switches. Not sure if the 1990 90's were culprit to the window switch problem. But the contacts inside the switch get corroded and need a little cleaning. Used to have to mess with them all the time on my 4K.
I had this problem on my B4 90....
On my '95 (B4) 90Q the sunroof and windows were on the same circuit. The circuit had a relay in the fuse panel area underneath the driver's knee bolster. I pulled the relay and replaced it with a "new" one and ...voila...everything worked.
Search "sunroof relay."
Again, I've never been lucky enough to own a CQ so I don't know if the wiring is the same.
Good luck,
Dave
Good luck,
Dave
oli1168
03-29-2011 09:27 AM
grnmtnquattro
01-11-2008 09:27 AM
audiauction
09-14-2006 01:34 PM
