Anyone know what fault code 2411 means? late build 20v cali car.
Old Aug 24, 2007 | 04:02 PM
Pre95's Avatar
Old Aug 24, 2007 | 04:17 PM
20VT90q's Avatar
Default That code doesn't exist accoarding to 20v.org
Maybe 2144 (knock sensor) as you are asking about it one post up?<ul><li><a href="http://20v.org/fault.htm">Fault Codes</a></li></ul>
Old Aug 24, 2007 | 04:26 PM
Pre95's Avatar
Default Found this, works with all blink codes from what I see
<ul><li><a href="http://www.intendedacceleration.com/fault_codes.html">Fault code page</a></li></ul>
Old Aug 24, 2007 | 04:53 PM
yodasfro's Avatar
Default 2411 per bentley
2411 Vacuum lines removed or bent EGR temp sensor bad.
Fuse (s28) bad. EGR frequency valve defective. per bentley manual
Old Aug 24, 2007 | 04:54 PM
Pre95's Avatar
Vac line was disconnected... 1 code down, next is knock sensor #2
JeffAhn
Feb 27, 2008 12:31 PM
Mr. Head
VAG-COM Discussion
Nov 21, 2003 12:38 PM
A4TURBO2 // TMK
Oct 28, 2003 12:35 PM
eroc
Feb 1, 2003 06:01 PM
Jeremy Clarkson
23
May 1, 2002 06:44 PM
