audi 80 cabriolet roof problems, help please!!!!!!
hi
this is the first time i have ever used this site and not too sure how it all works, i have just bought a 93 2.3 cabriolet and all has been fine, i put the roof down yesterday as i was investigating an annoyin noise. now the release nutton to put the roof away has stopped working. i used an allen key to put it away but still today it does not work, any ideas??? any help much appriciated
my e-mail is giloppi@aol.com
many thanks
many thanks
Could be a lot of things....search the forum here and you should find ...
some pointers where to look for a problem. For starters....you can change the search keyword for different results. make sure you select 80/90 forum.<ul><li><a href="http://search.audiworld.com/index.html?q=Cabriolet+roof+problem&u=&s=a ll&cat=010016&db=1999-01-01&de=2006-01-08">try this..</a></li></ul>
Re: Could be a lot of things....search the forum here and you should find ...
i have tried searching but cannot find exactly what i need, does anyone know exactly where the wires go, th button its self is live but when i push it the back wont pop up, it was working fine!!
thanks
thanks
Here are some pointers
The handbrake has to be on, the brake light bulbs have to work, the bootlid has to be shut, the doors have to be shut, the wiring has to be OK in the boot for the controller to know all this is working..
Check the bulbs
Check the bootlid wiring on the left side
It's not as simple as just the switch..
Check the bulbs
Re: audi 80 cabriolet roof problems, help please!!!!!!
thank you i will look into these, i did put a new boot stop rubber in on sat so maybe there is an interlock or something
cheers
cheers
nsantos23
09-01-2003 09:44 AM
shrtbus(w/ cq)
04-29-2002 03:33 PM
Adam S
10-20-1999 11:51 AM
