clutch pedal stuck to the floor :o(
i believe it the original clutch. the cq has 142,XXX miles.
i parked the car then got back into the car and pushed on the clutch pedal to start the car ans it got stuck.
Re: i believe it the original clutch. the cq has 142,XXX miles.
no probelms before? i would check for leaks. and test your slave and master cyl. if all check out then its the clutch!
$50 each plus labor
<ul><li><a href="http://www.autohausaz.com/search/groupx.aspx?sid=zs3mn255mwfnqf55if5yslay&makei d=800002@Audi&modelid=1009055@COUPE%20QUATTRO% 20&year=1990&cid=15@Clutch%20Parts">http://www.autohausaz.com/search/groupx.aspx?sid=zs3mn25
