Complete Heater/Fan unit. Can you imagine what it takes to remove this from the car?..BTW..
<center><img src="http://www.totsteile.ch/gebrauchtteile/s2b4typ89/s2coupeaby/klimaanlage/klimakasten.jpg"></center><p>
Look above the unit. Quattro drive shaft. Carbon Fiber unit?
Dont be too in love with the CF driveshaft. It weighs 55% more than the steel one!
its one of the first things to go away with my new motor and 4k tranny. Damn thing is too dense/heavy for max efficiency.
The universal in the CF shaft doesn't need to be re-lubbed as does the steel one...
That alone makes it worthy to me. The cabon fiber one is suppose to be more robust from certain Audi wrenches tell me.
Incorrect; they are the same regardless. Sealed for life with no lubrication provision...
Least on B4/5 applications. I've replaced more CF drive shafts out of necessity than steel ones. So has Champagne. And replacement costs on the CF unit make it a crazy idea (like $1700 new!). The joint is NOT replaceable on the CF unit while it is on the steel tubular shaft. I had to replace the CF driveshaft on my B5 2.8 due to the U-joint going bad and they arent rebuildable. Thats when I found the HUGE weight difference between the two. Bought a later model steel unit in the junkyard for $40 and had its u-joint replaced along with the center carrier bearing. Huge difference in "off-the-line" speeds. Reduced weight by 8-9lbs which is about the same as an 8-9lb lighter flywheel.
But I'm not trying to sell ya one. Just telling my experience and what I've learned over the years.
My CQ has the steel one. Though I had a CF one until I rapped it with a hammer.
It is the OEM piece. Never been replaced or any of it's parts replaced. Lucky I guess.
hijack: your swapping a 4k tranny in? Please enlighten me....
Care to share why your swapping in the 4k tranny? I've got an '87 4000cs quattro that I picked up recently that i'm still trying to figure out what i'm gonna do with.
Re: Complete Heater/Fan unit. Can you imagine what it takes to remove this from the car?..BTW..
My fan makes some noises and groans at me sometimes I hope it plans on sticking around a while longer.
GinCQ
09-22-2008 02:05 PM
KYNZ
11
08-10-2006 05:17 AM
treehunter
03-10-2005 08:27 AM
