Coolant On Ground?$# Help or Advice
The 1990 CQ 20 valve (95, 000 on the clock) has a broken temp gauge, and recently there has been coolant on the ground (intermittently). Looks like the hose's are in tact, the Radiator is new, so where should I look? The fan hasn't been kicking on while the car is running, but has run after shut down.(could this be my problem?, and if it is where should I start looking to fix the fan issue). Any tell tails for an overheated motor? Any and all help would be appreciated.
when my water pump was leaking, the coolant showed up here.
<center><img src="http://pictureposter.audiworld.com/72584/100_0178.jpg"></center><p>That is the front of the engine, about in the middle.
my96cab
04-01-2007 03:07 PM
hessteh@aol.com
08-02-2004 04:42 AM
Nvncibl
12v V6 Discussion
07-07-2004 03:10 PM
pitstop2001
14
05-14-2002 03:12 PM
