Dash Lighting Woes...
Old Aug 29, 2004 | 06:41 PM
The_Mizarc's Avatar
Default Dash Lighting Woes...
my dash lights didn't illuminate when I left work at 5 AM. provided it is nothing simple like a fuse does anyone have any ideas what the problem would be? Thank You
Old Aug 29, 2004 | 06:53 PM
Seanism (clone510)'s Avatar
trunk wiring
Old Aug 29, 2004 | 06:56 PM
The_Mizarc's Avatar
explain
Old Aug 29, 2004 | 07:18 PM
CvTech's Avatar
Default Is it just the dash lights?
meanin the instrument cluster, switches, climate control?
Do you have any exterior lights?
Old Aug 29, 2004 | 07:20 PM
Default Re: explain
also i know this sounds simple, but have you tried turning the dimmer *** for the dash lights, sometimes its gets turned down (or off) inadvertently<ul><li><a href="http://search.audiworld.com/index.mhtml?q=trunk%20wiring&amp;wf=022210&amp;m=a ll&amp;cat=010215&amp;dt=range&amp;db=01/01/1999&amp;de=08/29/2004">http://search.audiworld.com/index.mhtml?q=trunk%20wiring&amp;wf=022210&amp;m=a ll&amp;ca
Old Aug 29, 2004 | 09:22 PM
The_Mizarc's Avatar
headlamps work and I think tails also I'll Check when I get off in the morning
Old Aug 30, 2004 | 07:38 AM
audiquattroboss's Avatar
New Member
Default i got an idea!
make sure that you license plate light in teh back in plugged in... hmm... i know there are a couple more lights that come on with the dash... check what the fuse discription says... happened to me awhile ago... the dash lights wouldnt work.... i spent an hour checkin all the connections behind the dash and then went to the fuse panel... AGAIN... and started checkin what was on the fuse... turned out to be the connection in the rear... good luck man
ledzepp2994
Sep 28, 2009 12:00 AM
5000Q86
Jul 7, 2008 09:15 PM
sciroccohp
Jul 30, 2005 03:20 PM
AndrewsQuattros
Nov 12, 2002 05:28 PM
Mixer
Misc. Models Discussion
May 30, 2001 07:19 AM
