Diagnose this for me?
Hello folks,
Recently bought a 1995 Audi 90 Sport (FWD). I've been very happy with it for a 10 year old car. When I first bought it the gear shift was very smooth. But, it's not as smooth anymore especially at the start... 1st gear and the shift from 1st to 2nd. Sometimes, I need to double clutch to shift from 1st to 2nd. The rest of the gears give no problems. And no problems down-shifting either except from 2nd to 1st (again solved with double clutching). There is no grinding that I can hear or feel.
I've read a lot of informational posts here but I'm not too sure if this is a problem with synchros, fluids, the shifter or a combination of these since it's an old car. I figured it couldn't be the clutch since I don't feel any slippage but I'm no expert.
The car is pretty much stock and I don't drive it too hard.
What do you think this is?
Thanks,
Junaid
Thanks,
Junaid
VW transmissions don't like to go into 1st unless you're almost sitting still....
So the 2-1 shift doesn't surprise me. As far as the 1-2 shift, check your fluid and change if it you don't know when it was last changed. Take a look at all the linkage components to see if something is worn.
Worst case scenario: what happened to me. Hole in rear transmission case for selector shaft got "egged", so shaft could rock and didn't engage gears properly. Lost 5th and reverse. Had to buy a new rear case. Sucked.
Re: Even easier to change fluids
You're the smartest on your car. Do what you think is best. I've run into a problem with allowing others to diagnose for me. They normally point out the most expensive part first. Present company excluded!
