Differences in chassis S2 vs 90Q 20V
I need to know what the differences are in chassis on S2 and 90Q 20V.
I have a 90Q 20V with a S2 engine. To get the car approved as an S2, I need information regarding which parts I need to change.
Vincent
Vincent
S2 Sedan was only offered when the B4 chassis was released. And it was only a 6spd w/the ABY engine.
So, you techincally cannot register it as an S2 Sedan.
The S2 Coupes came as 5spd (3B engine) or 6spd (ABY engine). The 3B version is the closest you will find to your car. However, the front suspension is different (slightly). The wheel base is longer. The track is wider. Wheel bearing housings are different I think. Hubs and brakes are different. You will have to run CQ/S2 fenders, S2/B4-80 hood, S2 bumper, S2 headlamps. You will not use S2 brake lights or rear turn signals, they will not fit. Rear bumper is close enough to work.
blazej01
07-21-2018 08:04 AM
a9094
28
08-14-2011 12:19 AM
Naudi2U
04-01-2002 05:38 AM
