Does anybody know either the flow rate or the Bosch part number (m)
for the fuel injectors in the 12V engine (specifically the A4 in my case)
The injectors I have are Audi Part Number: 078 133 551 N, but I haven't been able to figure out the Bosch Part Number (need this in order to look up the flow rate).
Thanks,
Scott
Thanks,
Scott
Re: The Bosch number should be on the injector as well. Something like 0 280 150 100
Here's a few........
0 280 150 001 265 cm3/min
0 280 150 002 265 cm3/min
0 280 150 003 380 cm3/min
0 280 150 009 265 cm3/min
0 280 155 009 346 cm3/min
0 280 150 015 380 cm3/min
0 280 150 024 380 cm3/min
0 280 150 026 380 cm3/min
0 280 150 036 380 cm3/min MB 4.5l
0 280 150 041 480 cm3/min MB 6.9l V8
0 280 150 043 380 cm3/min BMW
0 280 150 100 185 cm3/min
0 280 150 121 178 cm3/min
B 280 410 144 434 cm3/min Bosch R-SPORT
0 280 150 200 300 cm3/min BMW
0 280 150 201 236 cm3/min
0 280 150 203 185 cm3/min
0 280 150 208 133 cm3/min
0 280 150 209 176 cm3/min Volvo B200-B230
0 280 150 211 146 cm3/min
0 280 150 335 300 cm3/min Volvo B230 turbo
0 280 150 400 437 cm3/min Ford 4.5l
0 280 150 401 437 cm3/min Ford
0 280 150 402 338 cm3/min Ford
0 280 150 403 503 cm3/min Ford
0 280 150 614 189 cm3/min
0 280 150 704 170 cm3/min
0 280 150 706 214 cm3/min 250kPa
0 180 150 712 214 cm3/min 250kPa Saab
0 280 150 715 149 cm3/min
0 280 150 716 134 cm3/min
0 280 150 762 214 cm3/min Volvo B230F
0 280 150 802 284 cm3/min Volvo B200
0 280 150 803 384 cm3/min
0 280 150 804 337 cm3/min Peugeot 505T
0 180 150 811 298 cm3/min 3.5kPa Porsche
0 280 150 814 384 cm3/min
0 280 150 834 397 cm3/min
0 280 150 835 397 cm3/min Chrysler
0 180 150 951 346 cm3/min Porsche Turbo
Thanks...stupid question though...
It's easy enough to get to the injectors, and it looks very easy to remove one, but do i need to do anything special before removing?
Thanks,
Scott
Thanks,
Scott
Re: Thanks........
Clean any dirt from around the injector seat, so it doesnt fall down the intake when the injector is removed.
Also be aware a good amount fuel will leak out from the manifold once the injector is removed. You might want to bleed the residual fuel pressure off at the connection nut, near the pressure reg before removing the injectors.
I normally remove the entire fuel rail, with the injectors attached, then remove the individual injectors from the rail. Their held on good by their sealing washers.
3rd_AyFour
12-17-2005 12:19 PM
xr4tic
01-06-2004 03:21 PM
