does anyone know the transmission code for the 4.11 tranny...
that came with the 3B engine in the 200? i know most of them were 3.89 final drives, but i had heard somewhere that a handful were made with 4.11. does anyone see a reason why this wouldn't work in my coupe?
thanks.
thanks.
The 200TQ used the AUM or 016 transmission........
This is the same basic transmission that was used in the UrQuattro. Granted this is a 4.11 transmission, but the coupe used an 01A transmission. I do not know if you would be able to set up the shifting mechanism correctly. Also you would have to take a look at whether you torson would line up. If the transmission is a different length than the coupe, you would have a problem with the length of your driveshaft.
May not be worth all the headache.
Re: The 200TQ used the AUM or 016 transmission........
And the front drive shafts (er, half shafts) I believe are larger on the 016 vs the 01A. I don't think the 01A's will fit the 016.
CoOlSlY
07-25-2004 04:41 PM
Passat_B5
03-05-2003 06:04 PM
Ben's e//S2
01-31-2003 08:38 AM
Mike O.
Quattro: Turbo / Ur / Sport
12-27-2001 08:45 AM
