Heated washer nozzles???
#13
Yeesch, don't log on for a day and miss the action!....So..
IqDOU, that would make sense. Particularly my passenger door -if I hold that handle up for a minute, the lock thaws. Not sure if the driver's door works. Too impatient to stand there holding the handle like a dork - people think you're stuck to the door or something. And if the washer nozzles are heated, that doesn't prevent the lines from choking up, right? Anyway, is there an easy way to check this?
#14
Yes, easiest way to check them would be with....
..a multimeter. Check to see if there is power going to them. Then check if the ground is good. Then check to see there is a good connection passing through the nozzle (measure resistance).
If all of those are okay then you should be fine!! HTH!!
drvai
01-08-2015 03:59 PM
Regenmeister
11-23-2005 05:53 AM
Randolph
10-01-2004 06:21 PM
MarkN
01-29-2002 05:45 AM
