How do I adjust ABS sensors?
Quattro, and ever since then whem I press the brake
my ABS kicks in BUT ONLY BELOW 5mph. Go figure.
So I'm thinking they must have knocked a couple
of the sensors out of place when they did the
alignment. So how do I adjust them back?
Thanks!
Paul
How does one adjust the ABS sensor gap?
One of mine was rubbing on the axle and I pulled it out to check and clean it (it's scraped up so I may need a new one) but obviously, when I put it back in, it's not adjusted correctly because I get the same problem as OP has.
For now I took the ABS/Cruise fuse out since it's much safer to drive that way.
I'd like to be able to fix the issue but haven't found the adjustment procedure yet.
Anyone able to give me a clue?
Thanks.
ABS was working before but started to go on and off and I started hearing scraping coming from that one side. I must have hit it while replacing tie rods or ball joints or upper stut mounts or something...
If you want them to work you can pull the fuse in the relay under your drivers side rear seat. I did that and pulled the light after I gave up trying to fix mine.
Once I get to the cruise control diagnostics, then it'll have to go back in but I'm hoping to actually fix the ABS...
let me know how you fix the cruise if and when you do - I feel like it might be as simple as vac leak in the system - I think there are o-rings that fail as part of assemblys attached to each pedal.
I'll be plugging in and testing the cruise system at some point. The Bentley for the 1997 Jetta has a very straight forward method, I'll just need to see if I can determine the "matching" pins on the Audi because the systems look extremely similar.
The tests will determine which components are at fault and is done without the module in place. If the test pass, it means it's a bad module.
