I have a rattlin' tie rod
I went in for an alignment, but they couldn't do it because the tie rod on the driver's side needs to be replaced. Since then I've been getting a rattling from that area, seems to have gotten worse/more frequent as well.
So my questions are how concerned should I be and what can I do to "fix" it until the new tie rod comes in?
maybe, see the nut on the shaft of the tie rod end may not be tightened down all the way
1. because the shaft was spinning or 2. because the threads get all mucked up. If its #1, maybe, if #2...no, just get a new end or in my opinion, new rod assembly. If #1 though, you can tell because the nut come on and off easy and right about when it should be tightened 90% the shaft and nut will just spin spin spin. You can place a piece of 2x4 wood under the knunckle and give it some pressure then try to tighten slowly...air tools help as well, but tighten like that. If it keeps spinning, jack it more and try.
Max_A6
Mid Atlantic Discussion
03-14-2007 11:40 AM
CK:1.8T+Rabbitâ„¢
10-29-2005 11:30 AM
Small Town Terrorist
Audi allroad
05-27-2005 01:24 PM
Hokie - STI avant
06-10-2003 11:06 AM
