Miktip, you mentioned the fuel block going bad on my 1990 audi 4cyl
I tried switching the ecu but it did not help. I did the cis systematic check and I do not think anything was out of spec enough to warrant a problem.
The car runs lean at idle and the ecu also gives code
2344: Mixture control rich limit: Idle NOT OK, Intake system leaks: Check intake system; adjust idle.
There are no leaks of air evident and I believe the problem is from the MAF senso fuel distubutor.
The exhaust is execesively noise at idle and quite when the engine revs.
What can you tell me about the problem with high mileage fuel distributor?
I plan the check the MAF electricly and test fule pressures.
Dave
1990 audi 80 207,000
1986 Coupe GT CE turbo
Dave
Re: Miktip, you mentioned the fuel block going bad on my 1990 audi 4cyl
can u tell me what is wrong with u`r car in details(power loss not idling when cold or whatever else)maybe i can help
krzysztofkow
05-25-2018 04:59 AM
PearlA4_1
12v V6 Discussion
01-24-2004 04:42 PM
Catamount90
01-06-2003 08:57 AM
