ok CV my Rear tires seem to be like yours (drivers Low Pass Hi)...
what have you done allready to try and figgure this out??
Have you removed either of the rear sturt/shock assamblys?
yeah, I removed em both.
I can't tell any difference in setup. My latest thinking is just that the springs compress differently. And to be honest its not even THAT noticeable. You can see it if its pointed out. Rob saw it. But its hard to tell. My driver side looks hot, I can barely fit my finger in under the wheel well and over the tire. On the passenger side they go in no problem. But I do get rubbing on the driver side at some points. Kinda freaks me out at higher speeds.
I had Vog's and Bils and didnt see any problems.
Have you checked the struts? The side that is lower, remove it and check the compression on the strut. I am guessing you know the diffrenst between a bad strut and a good strut?
yeah, they were good when I checked em last
I got em new and all, I just think its something I am gonna have to live with or add or subtract something from one to even it out. Who knows. I am def not concerned about it it, its just kinda annoying.
