Powersteering fluid leak!!
Old Nov 12, 2002 | 05:22 AM
quattromano's Avatar
Default Powersteering fluid leak!!
On 20V engines, the powersteering hose coming from the pump to the reservoir goes across the front of the radiator then sneaks around the side of the radiator and the washer bottle for the headlites.
I have a leak somewhere there. There is a clamp and what looks like another hose it is attached to. Where in that area can fluid leak out of? Is the powersteering reservoir cracked under there? Is that possible? It's driving me crazy. Help anyone.
Old Nov 12, 2002 | 07:01 AM
QCRAZY's Avatar
Default This section is made up of about three (or four?) seperate hoses....
Check all the connections. Also, check the hose clamp/connection at the bottom of the reservior!
Old Nov 12, 2002 | 09:24 AM
Audi_kid_BC's Avatar
New Member
Default go get some stop leak
I had a leak and I went and got some stop leak.
I used a similer product and I havent had problems since.
try it first and if it persists in a month check it out further<ul><li><a href="http://www.wynns.be/Products/Products/Prof/1Oil/PowerSteering.htm">super duper steering fixer upper</a></li></ul>
Old Nov 12, 2002 | 09:27 AM
QCRAZY's Avatar
Don't use this stuff!! It's not going to be compatible with Pentosin!
95naudi90
Sep 28, 2007 06:39 AM
Regenmeister
Mar 31, 2006 12:41 PM
AUDIA4_TDI
Feb 5, 2004 03:25 PM
lukin36
Dec 18, 2002 06:19 PM
George H
Feb 24, 2000 09:26 AM
