Sprung a leak
Old Feb 24, 2000 | 05:29 AM
George H
Guest
Posts: n/a
Default Sprung a leak
Okay, it is only windshield washer fluid leaking but still...anyone seen before? Leak is from driver side below the headlight, slow but leaving blue stains in the garage. Seems independent of level of fluid, and I can't see any obvious cracks in the resevior.
Old Feb 24, 2000 | 05:33 AM
George H
Guest
Posts: n/a
Re: Sprung a leak - oh yeah, 2.8QM, 98 out of warranty
Old Feb 24, 2000 | 05:35 AM
Kyle Bailey
Guest
Posts: n/a
Default Could be a hose clamp
I had a leak in the same general area. I happened to be changing the oil so I had the belly pan off and could see where it was coming from. However, I couldn't get access to the clamp, so I wiggled the hose until it stopped leaking.
The hose clamps that Audi uses tend to get loose as the rubber ages, and as far as I can tell there is no way to tighten them, at least not without a special tool. These calmps are also the cause of the common power steering fluid leak.
Kyle
Old Feb 24, 2000 | 07:52 AM
mm
Guest
Posts: n/a
Default Search the archives using washer, leak, and reservoir as keywords.
I believe some have experienced leaks at the washer fluid pump. You should be able to find more info in the archives.
Old Feb 24, 2000 | 09:00 AM
Dank
Guest
Posts: n/a
Very common problem. Take it to dealer, they'll order parts without even checking...
Old Feb 24, 2000 | 09:26 AM
brian W
Guest
Posts: n/a
Default same prob here.. turned out to be a nightmare!
brought my car in because she was drooling windshield washer fluid everywhere..
bellavia took it apart and found out that the tank was cracked.. they ordered the part.. took about 6 weeks for the tank to come in.. took the day off work so that i could bring my car in.. tank was the wrong one.. the box it came in was correct, the contents were incorrect.. waited another 8 weeks for the right part to come in.. bellavia this time gave me a loaner (thanks joe!). as they were replacing the tank they noticed that the passenger side headlight washer was broken.. that was 4 weeks ago.. still waiting for the call........ ugh.
the worst part of this whole thing is that this happened during winter, and this winter was particularily bad here in nyc. i'm sure i looked funny while driving down the highway pouring windshield washer fluid directly onto my window @ 55mph!
good luck.. and make sure they check out the WHOLE system before ordering any parts and calling you in.
regards,
brian
lavezzaf - Anthony
Jun 8, 2008 05:50 PM
Regenmeister
Mar 31, 2006 12:41 PM
Skizsam
Jan 15, 2004 04:46 AM
quattromano
Nov 12, 2002 09:27 AM
mattisthebomb
Aug 16, 2002 11:43 AM
