Replacing clutch master & slave soon (this weekend?)...some questions (CQ).
I know where both are and the physical replacement doesn't look too bad. However, I am not sure how to bleed either of them. I've replaced and bled brakes before, but I'm not really sure how to bleed the clutch system. Any advice on the clutch bleeding procedure? Do I need to pre-fill the cylinders like you do on new calipers?
Also, I just replaced my rear calipers, so the whole brake system needs to be bled. Should I do the clutch and brakes at the same time? Or should I do the brakes first and then the clutch?
Thanks,
Scott<ul><li><a href="http://www.motiveproducts.com/">Brake bleeder that I have...</a></li></ul>
Thanks,
Re: Replacing clutch master & slave soon (this weekend?)...some questions (CQ).
In this order for bleeding
brake master cylinder
porportioning valve
right rear
left rear
right front
left front
clutch slave cylinder
bleed the clutch the same way you do the brakes.
HTH, Ben
porportioning valve
right rear
left rear
right front
left front
HTH, Ben
Thanks Ben...a couple more questions.
Do either the clutch slave or clutch master cylinder need to be pre-filled with fluid (like a brake caliper does)?
Does only the slave cylinder need to be bled, or do I need to do the clutch master cylinder as well?
Thanks again,
Scott
Thanks again,
Scott
Re: You don't need to bleed the clutch master...
because there isn't a bleed valve IIRC. I didnt fill my slave with fluid and it works fine. But fill it if you want to be safe as it won't be hard to do.
90QuattroKid
13
03-16-2009 08:38 PM
20vqtro
03-02-2009 07:23 AM
Detonator
07-28-2008 11:09 AM
Beartrax
03-09-2006 03:20 AM
