Solid mount upper seal replacements for stock Audi dust caps are now available...
<center><img src="http://pictureposter.audiworld.com/711/mountseal1.jpg"></center><p>
Here's the pic of the 2 part seal system consisting of a precision o-ring to fit between spherical bearing and mount and a 24mm press-on nut cap.
First blow out any dust/debris in bearing with compressed air or a soft bristle brush then:
Left of pic: Press o-ring over top of bearing
Middle of pic: If bearing is mounted in car slip o-ring over strut nut.
Right of pic: Once nut is tight just press nut cap over 24mm nut. It is such a tight precision fit on the 24mm strut nut it will retain the o-ring in the groove below.
Even high pressure water from a self-service car wash can no longer get past the seal this provides.
You can get pricing info from where you purchased your Mance Mounts.
do you think it would work with a 86 4kcsq?
i will be needing to replace those mounts on it when converting it to my track car with my new old 12v aah engine..now i need to get the other parts for it as well..
dfinn
09-27-2005 01:49 PM
VAP
9
12-20-2004 02:01 PM
VAP
15
12-11-2004 01:52 AM
