what pressure are the 12v fuel injectors benched at?
havin trouble getting my ur-quattro to idle right with 12v injectors and efi. runnin 35 psi now, but want to know the 170 cc min at what pressure?
4 bar (58.8psi) tho the 12V FPR is a RRFPR (rising rate fuel pressure regulator)
at idle manifold vacuum lowers the pressure to closer to 3bar. If you want specifics you need to install a manifold vacum gauge to see where the FPR is psi-wise at "X" degree of throttle opening. At WOT its 4bar. Rule of thumb value is less 1psi per inHg manifold vacuum.
cparke
11-28-2008 02:03 PM
thewatcher101
06-23-2007 06:41 AM
moribundman
12v V6 Discussion
07-07-2004 04:07 PM
