Wiring update on 20vt project...
For all those planning on doing a similar project, this is what you get to look forward to. I finally got the 200's harness out and despite telling myself over and over again to label things....I forgot. So Saturday I spent some time identifying and labeling all the connectors. If you spend enough time looking at wiring schematics you start to figure them out!! Here are a couple of connectors I am unsure of. The first is the last connector, furthest away from the ECU if you were to stretch the harness out. As you can see in the picture I am holding both sides of the connector and then behind it is where it goes. (Near the shift housing, by the airbag control unit)
<img src="http://pictureposter.audiworld.com/2752/wire1.jpg">
This next one I am positive it was from one of the column switches, probably has to do with cruise control.
<img src="http://pictureposter.audiworld.com/2752/wire2.jpg">
Don't let this intimidate you. The wiring just takes time and effort to understand.
When and if i do that im dedicating a FULL two or whatever weeks to do it all.....
in one huge job, so that you don't forget things and have to back track.
Nate (ETKA+Scumbag)
08-09-2006 07:43 AM
Forest
04-17-2003 07:56 AM
BigMouse
08-28-2002 06:35 PM
