2015 Audi A3 Overheating / Thermostat / Sensors???
I'm having a problem with my 2015 1.8T Audi A3 with 799222k miles. My dash is currently showing the EPC, 4k max RPMs, Check engine, and TPMS (possibly unrelated) lights. I have taken it to two separate mechanics. I have attached the work done by the both. Most recently I had the coolant valve replaced. However, after all of the work was done my temperature gauge shows just under overheating when driven more than 5-10 minutes or during idle. In addition to these problems, it shifts gears poorly and when driving RPM's run a lot higher in between gear shifts.
First repairs and diagnostic report. Had about 72k miles on it
See above
Second repair plus diagnostic report. After reportedly fixed EPC & Max 4000 RPMs appeared. Brought back in 5 minutes. Mechanic stated it was a loose hose. Code was gone for a while. About 75k miles atp.
Most recent mechanic visit (in a different state). Said it was working fine at pick up and ran well. But a day later EPC and max RPM came on again. It went away one time for almost a day, car ran much smoother until codes came back on again.
I'm at a loss for what the cause could be. Has anyone else experienced this?
See above
CBVaughan
10
06-12-2014 06:43 AM
KMHPaladin
12v V6 Discussion
01-22-2004 06:09 PM
