Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
rear hatch problem
Old Sep 19, 2007 | 07:36 AM
Steve_Ag Arrow's Avatar
Default rear hatch problem
<center><img src="http://pictureposter.audiworld.com/5987/100_3564.jpg"></center><p>Just the other day my center display showed that the rear hatch was open. I closed it again and it was closed, still get the message. I also try the rear wiper and it doesn't work either. The car doesn't beep when I lock the car but that makes sense because it doesn't sense that the rear is closed. Any idea what the problem is? I am out of warranty.
Old Sep 19, 2007 | 07:41 AM
1heartaudiworld's Avatar
Junior Member
more then likely the sensor in the actual latch assembly
Old Sep 19, 2007 | 08:49 AM
absoluTT A3's Avatar
Default Is it something you can attend to yourself or is a replacement part necessary?
On my former TTQR, the soft top closure sensor would bend over time, creating a slight gap that would fool the OBC to conclude that the top wasn't closed (and thus mess up window positions). Turns out you could easily bend it back into place with a screwdriver.
Old Sep 19, 2007 | 09:10 AM
Junior Member
Default It would really depend if it ws a matter of the tab bending or the sensor itself bad
it would be in the upper part of the hatch, the actual door part. You would need to replace more then likely the entire latch assembly as the switches seem to be coming built into them lately.
Private Harry
Q5/SQ5 MKI (8R) Discussion
Mar 2, 2019 12:49 AM
Delusory
Apr 30, 2016 01:15 PM
Icemate
Oct 22, 2013 08:14 AM
Tr00p3r
Apr 3, 2008 05:18 PM
apfelbaum a6
Aug 12, 2006 04:02 AM
