Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
What size SD card?
Old Oct 11, 2007 | 09:59 AM
formerly dennisA4's Avatar
Default What size SD card?
What's the max size I can use in the nav for mp3's and is there a 99 song limit on each card?
Old Oct 11, 2007 | 10:07 AM
DirkM's Avatar
max 4GB SD (not SDHC), 512 objects limit each card
Old Oct 11, 2007 | 10:09 AM
Silver_Patrone's Avatar
Default there is a limit to 500 files ( files and folders) so 2GB will hold about 350- @ 256BPS-
And 4GB will hold all 500 but have about 1 GB free- so i use 4 - 2gb cards-
also if you get 4GB you can not use the SCHC cards- only standard 4GB will work so you will have to go off brand as all the good makers of SD cards- will be SDHC above 2GB.
Craig
Old Oct 11, 2007 | 10:16 AM
Gettysburg's Avatar
Default I was under the impression it was a 256 file/folder limit
I use 2 GBytes SD cards without problem. Posters on Navplus.us forum have mentioned using 4GByte without problem, but with a 256 file limit, you may not be able to fill a 4 or 8GByte card anyway.
Old Oct 11, 2007 | 10:19 AM
Thanks!
Old Oct 11, 2007 | 12:50 PM
pipplo's Avatar
New Member
Default Shameless plug
But you can check out my tool I created to help organize and synch mp3s to your SD card
http://a3synch.koston.net/
Except i just read that you have a MAC so you can't I guess.
Nevermind sorry
Old Oct 11, 2007 | 01:08 PM
Gettysburg's Avatar
Default Houston, We Have a Problem.
The following error message appears before the main application window is displayed.
<img src="http://pictureposter.audiworld.com/89897/error.jpg">
Old Oct 11, 2007 | 04:41 PM
agentwithA3's Avatar
Default Given that 2 cards have same GB rating and same files loaded...
Can some SD cards load or transfer info faster than others? Thanks!
Old Oct 11, 2007 | 07:23 PM
Gettysburg's Avatar
Default I've got a 2 SanDisk cards and two PNYcards, and..
I'm able to transfer files to the SanDisk cards more quickly than the PNY.
Old Oct 12, 2007 | 07:22 AM
Default When I start the car in the morning one brand of card "loads" in the RNSE faster
than the other.
