17" Wheels on a 2018 A3 (factory 18")
Hello all,
I have a friend who has 17" wheels with tires (225/45 R17) from an A4 which he is selling. Will they fit on my 2018 A3 Premium plus?, it came with the 18" wheels originally.
Thanks,
Vinny
Thanks,
Vinny
Audiworld Senior Member
17" wheels "should" fit but to know for sure you also need a few other bits of information such as wheel offset for OEM and new wheels. See my post
https://www.audiworld.com/forums/aud.../#post25188019
Digging into this, it looks like the rims I am looking to get have an offset of 47mm. My factory rims which came with the Audi have an offset of 46mm. Is it OK to deviate a little bit from the stock ones?
If the wheel widths are the same and the offset is only 1mm different, I would say not a problem. Having said that, you should make the measurements I refer to in my prior post to be sure.
This shouldn't cause a problem right?
Not sure - you may need wheel centering rings to ensure the wheels are properly centered. If not, you may experience some vibration. Check out this Tire Rack link for more info: https://www.tirerack.com/tires/tiret....jsp?techid=91
Tom Faust
02-15-2005 01:33 PM
OpusK551
Wheels & Tires Discussion
11-21-2001 06:57 AM
