MMI screen stuck closed
Pretty pathetic on a car less than a year old. I can't really use any of the MMI functions until Audi fixes this.
Will let you all know what they say and do
CNTL-ALT-DELETE!
I will try tonight and post an update.
Hold that thought!
After being left to sulk in the garage for a day the MMI decided to work perfectly as soon as i turned on the ignition - Even though I had tried several times last night. So I don't know if the reset will work, or even what was up with it. I guess i will just have to keep an eye on it. I did take a video so as a minimum I can get Audi to look at it next time i take it in for service.
Glad you hear it's working again! But that does suck not knowing what caused it to malfunction in the first place. Intermittent problems can be frustrating for sure. Was your car in unreasonable heat or cold recently? I work with electronics now and the constant up/down movement of the MMI did have me worried initially when I bought the car. More moving parts means more that can go wrong at some point. Think all other Audis have static or fixed displays. Audi is going to that new instrument cluster display thing as well. Not sure I would like a moving map right where the tach and speedo are supposed to be.
Hope you never see the MMI problem again.
quattro nole (Jeff)
Rocky Mountain Discussion
16
02-12-2007 05:28 PM
Bramell-EVOvert
10-22-2003 06:53 AM
85-4kq-girl
22
08-18-2003 07:24 AM
