other tire sizes? RS3
Anybody try a 255/35-19 front, 245/35-19 rear on a RS3 ? trying to find a all HP all season set to fit on stock wheels for the cold months up here, wondering if these will clear everything. the front goes from 25.1 to 25.9 in height
The most common alternative tire size I’ve seen people run is the 245/35 square setup suggested above. Seems to be a pretty natural/easy swap. If you’re looking for a winter set basically, you could switch to a set of 18 inch wheels if you wanted something a little more versatile.
There's lots of 18" fitments, and 255's fit with plenty of room all around. I have two sets, 18x8.5 ET35 with 255 square and 18x9 ET30 with 255/235. Running 245 in the back or a square setup introduces more understeer which would be perfect for a winter setup but not so fun in the summer. I plan to go the other way and run 265/235 next time but we don't get snow here. For winter, 225 and some tall sidewalls would probably be more ideal.
Not my post but here is a list of confirmed wheels that fit.Contact Paul for more info: Paul@SupremePower.com
Because the RS3 holds a special place in my heart, I wanted to try and take some of the frustration out of choosing wheels that fit due to the large caliper and small MQB architecture combo.
What I've decided to do is use Post #1 and Post #2 for manufacturer confirmed wheel fitments without spacers and in what specs for the 8V RS3 Sedan. Meaning, I have contacted the manufacturer and they have confirmed by either test fitting or via craft expertise that those options will work.
I'm going to use Post #3 to list manufacturer confirmed fitment with spacers with the suggested spacer width. I will also use Post #3 for Custom wheels. Additionally, I’d like to do a section with Audi OEM fitments but that may have to be member confirmed only because Audi tends to not go on the record for "off-label" use of anything (End of Post #3).
This is not an all inclusive list of manufacturers but I will do my best to keep adding fits. I'm always waiting on other vendors to reply so I will be updating it as often as I can so check back for the most current info.
If any one has any requests for confirmed fitment, post the manufacturer name, wheel line, diameter, width and offset. Ill do my best to confirm it and update it into the appropriate Post.
If anyone wants quotes on anything please email me "Paul@SupremePower.com" instead of posting so we can keep the thread concise.
Note: Post #1, #2 and #3 info is meant to be used as a guide for the rims on Standard (non-lowered) and Oem camber cars. Tire brand and size may affect the final mounted fit and look on the car. If a manufacturer supplied a recommended tire size I included it but other sizes may be possible.
This info shouldn’t change but anything is possible so please make sure you make a final confirmation with the manufacturer if you place an order elsewhere.
*** Ride height effects clearance/rub ***
***Most of the wheel pictures are stock photos and are only to show the wheel style. They do not represent the confirmed specs in profile concavity***
Summary:
Post #1 & #2
-Confirmed fitment without spacers
Post #3
-Confirmed fitment with spacers
-Custom fitments
-Member confirmed OEM fitments
Confirmed options so far without using spacers:
ALTI
19x9.5 +45
BBS
CC-R 2302
19x9.5 +42 *aggressive fitment*
Also good with CCB
RF 527
18x8.5 +38
LMR 322
19x8.5 +38
LM 273
20x8.5 +38
CH-R
20x8.5 +40
Clears standard brakes only
19x9.5 +45
FS
19x8.5 +42
Clears CCB
19x9.5 +45
CI-R 2201
19x9 +42 Square
(Silver lip protector is removable)
Or use with:
CI-R 2103
19x8.5 +45 on Rear only for front staggered setup
CI-R Nurburgring Edition
19x9 +42 Square
Or use with:
XA 0202
18x8.5 +35
RI-A 023
18x8.5 +45
VORSTEINER
VFF 102
20x9 +35
VFF 103
20x9 +35
VFF 105
19x9 +40
245/35 max
VFF 107
20x9 +35
245/30 max
VFF 108
19x9 +40
VMR
V801
19x8.5 +35
245/35 max
Also good with CCB
V804
19x8.5 +35
245/35 max
V710
19x8.5 +35
245/35 max
Also good with CCB
NEUSPEED
RSe11R
18X8.5 +45 with 235 or 245 tires (center mount outer balance weight)
18X9 +40 with 245 or 255 (narrow)
18x9 +45 with 255 or 265 tires
18X9.5 +45 with 255 max. Rear DOT fender tab may need removal
Above also good with CCB
RSe142
19X8.5 +45
19X9 +40
19x9 +45
19X9.5 +45 with 255 max. Rear DOT fender tab may need removal
RSe122
18X8 +45 REAR ONLY
RSe 102
19x9 +40
19x9 +45
19x8.5 +45
19x8 +45 REAR ONLY
20X9 +40 with 245/30
RSe 10
19x9 +40
19x9 +45
19x8.5 +45
19x8 +45 REAR ONLY
18x8.5 +45 with 235 or 245 tires (center mount outer balance weight)
18x9 +40 with 245 or 255 tires (narrow)
18x8 +45 REAR ONLY
RSe 52
18x9 +40
245/40 square or
265/35 Front & 245/40 Rear
VOLK RACING
G25
19X8.5 +38 and +45 (+38 may need 3mm spacer in NA & ROW vehicle)
18x9 +45 (member confirmed post #536)
18x8.5 +42
ZE40
19X8.5 +44
TE37 ULTRA
19X8.5 +38
G27 Progressive Model
19x8.5 +38 Square
19x9 +48 Square or use with above for front stagger
HARTMANN
HRS6-091-MA
19X8.5 +38 W/ 235 OR 245 TIRES
HRS6-204-GS
HRS6-204-MA
HRS4-252-GS
20X9 +40 W/235 OR 245 TIRES
HLP-410-GS
Summary:
Post #1 & #2
Post #3
-Custom fitments
ALTI
19x9.5 +45
BBS
CC-R 2302
Also good with CCB
RF 527
18x8.5 +38
LMR 322
19x8.5 +38
LM 273
20x8.5 +38
CH-R
20x8.5 +40
19x9.5 +45
FS
19x8.5 +42
Clears CCB
19x9.5 +45
CI-R 2201
19x9 +42 Square
Or use with:
CI-R 2103
19x9 +42 Square
Or use with:
XA 0202
18x8.5 +35
RI-A 023
18x8.5 +45
VORSTEINER
VFF 102
20x9 +35
VFF 103
20x9 +35
VFF 105
19x9 +40
245/35 max
VFF 107
20x9 +35
245/30 max
VFF 108
19x9 +40
VMR
V801
19x8.5 +35
245/35 max
Also good with CCB
V804
19x8.5 +35
245/35 max
V710
19x8.5 +35
245/35 max
Also good with CCB
NEUSPEED
RSe11R
RSe142
19X8.5 +45
19X9 +40
19x9 +45
RSe122
18X8 +45 REAR ONLY
RSe 102
19x9 +40
19x9 +45
19x8.5 +45
19x8 +45 REAR ONLY
RSe 10
19x9 +40
19x9 +45
19x8.5 +45
19x8 +45 REAR ONLY
18x8 +45 REAR ONLY
RSe 52
18x9 +40
245/40 square or
VOLK RACING
G25
18x8.5 +42
ZE40
19X8.5 +44
TE37 ULTRA
19X8.5 +38
19x8.5 +38 Square
HARTMANN
HRS6-091-MA
HRS6-204-GS
HRS6-204-MA
HRS4-252-GS
HLP-410-GS
Not my post! Contact Paul for more info: Paul@SupremePower.com
Manufacturer Confirmed Fitment Without Spacers CONTINUED
HARTMANN Continued
HR8-GA
19X8 +35 W/ 235 OR 245 TIRES
HR8-GS
19X8.5 +47 W/ 235, 245 OR 255 TIRES
AVANT GARDE
M510, M540, M580, M590, M610, M615, M621, M632
19x8.5 +32
235/35 Or narrow brand 245/35 max
M652
19x8.5 +32
ADVAN
Advan RS-DF
19x8.5 +45
Advan RGIII
19x8.5 +45
Advan GT
19x8.5 +42
18x9 +45 - member confirmed
Advan RZII
19x8.5 +45
Advan RSII
19x8.5 +42
AVS Model F50
19x8.5 +42
OZ RACING
SUPER LM
19X8.5 +44
GOOD WITH CCB ALSO
HYPER GT
19X8 +35
235/35 max
GOOD WITH CCB ALSO
ULTRA HLT
19X8 +35
235/35 max
19X8.5 +32
19X8.5 +38
245/35
19X8.5 +47
SEBRING
19x8.5 +32
HRE
FF01
19x9.5 +45
255/30
FF04
19X9.5 +45
255/30
FF15
19x9.5 +45
255/30
ABT
GR20
20x8.5+45
ER-C19
19x8.5 +35
245/35 max
TARGA
TG3
19x8.5 +45
20x9 +42
TG2
19x8.5 +45
HARTMANN Continued
HR8-GA
HR8-GS
AVANT GARDE
19x8.5 +32
M652
19x8.5 +32
ADVAN
Advan RS-DF
19x8.5 +45
Advan RGIII
19x8.5 +45
Advan GT
19x8.5 +42
Advan RZII
19x8.5 +45
Advan RSII
19x8.5 +42
AVS Model F50
19x8.5 +42
OZ RACING
SUPER LM
19X8.5 +44
GOOD WITH CCB ALSO
HYPER GT
19X8 +35
235/35 max
GOOD WITH CCB ALSO
ULTRA HLT
19X8 +35
235/35 max
19X8.5 +32
19X8.5 +38
245/35
19X8.5 +47
SEBRING
19x8.5 +32
HRE
FF01
19x9.5 +45
255/30
FF04
19X9.5 +45
255/30
FF15
19x9.5 +45
255/30
ABT
GR20
20x8.5+45
ER-C19
19x8.5 +35
245/35 max
TARGA
TG3
19x8.5 +45
20x9 +42
TG2
19x8.5 +45
Manufacturer Confirmed Fitment With Spacers (Unless otherwise noted):
VORSTEINER
VFF 101
19X8.5 +45
8mm Spacers
245/35 max
VFF 103
19x8.5 +45
8mm Spacers
245/35 max
VFF 105
19x8.5 +45
8mm spacers
245/35 max
VFF 107
19x8.5 +45
8mm Spacers
245/35 max
VOLK
TE37 ULTRA
19X8.5 +45
3mm Spacer
HARTMANN
HRS7-163-MA
3mm Spacer
HTT-256-MA
3mm Spacer
20X9 +40 W/ 235 TIRES ONLY
3mm Spacer
HLP-410-GS
3mm Spacer
HRE
FF01
19x8.5 +47
8mm Spacer
(member confirmed)
Enkei
RS05RR
18x8.5 +45
10mm spacer
(Member confirmed. Thanks to kevinlee709)
CUSTOM FITMENTS
These are just some examples of custom style and specs that will work. Many others are possible so email me if you want a specific custom style and spec combo. In the interest of saving space in these posts I will link to custom fitment in lieu of pics below unless I have a specific RS3 custom wheels possibilities to show or that have been done.
FORGELINE
VX1
20X9 front +47
20X9 rear +44
245/30 Michelin tires
BC FORGED
HCS21
19X9.5 front
19x9.5 rear
BC FORGED MONOBLOCK RS3 CONFIRMED FIT LINES (offset varies)
KLS series:
KLS02
KLS03
BC FORGED MODULAR RS3 CONFIRMED FIT LINES (offset varies)
FJ SERIES RS3 STEEL BRAKES FITMENT AVAILABLE IN:
19x9
19x9.5
+40 to +45
30mm to 50mm lip
Workable spec configuration depends on square or staggered offset
VOSSEN
VPS-315T
19" Custom offsets
ROTOFORM
Forged lineup:
http://www.rotiform.com/forged-c-4197.htm
SIGNATURE WHEEL
Full collection:
https://www.signaturewheel.com/products
AUDI OEM MEMBER CONFIRMED FITMENTS
R8
19X8.5 +42
No Spacers
Thanks to Steve B. from the FB S3/RS3 Owners Group for pic
S4 Peelers
19x8.5 +43
No spacers
255/35/19 Blizzak LM-32
Thanks to Edward L. From the FB S3/RS3 Owners Group for pic
VORSTEINER
VFF 101
19X8.5 +45
8mm Spacers
245/35 max
VFF 103
19x8.5 +45
8mm Spacers
245/35 max
VFF 105
19x8.5 +45
8mm spacers
245/35 max
VFF 107
19x8.5 +45
8mm Spacers
245/35 max
VOLK
TE37 ULTRA
19X8.5 +45
3mm Spacer
HARTMANN
HRS7-163-MA
3mm Spacer
HTT-256-MA
3mm Spacer
3mm Spacer
HLP-410-GS
3mm Spacer
HRE
FF01
19x8.5 +47
8mm Spacer
(member confirmed)
Enkei
RS05RR
18x8.5 +45
10mm spacer
CUSTOM FITMENTS
FORGELINE
VX1
20X9 front +47
20X9 rear +44
BC FORGED
HCS21
19X9.5 front
19x9.5 rear
KLS series:
KLS02
KLS03
19x9
19x9.5
+40 to +45
30mm to 50mm lip
VOSSEN
VPS-315T
19" Custom offsets
ROTOFORM
Forged lineup:
SIGNATURE WHEEL
Full collection:
R8
19X8.5 +42
No Spacers
S4 Peelers
19x8.5 +43
No spacers
