Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
Super Bright LED Reverse lights installed
Old 01-08-2016, 05:27 PM
markN1689's Avatar
Default Super Bright LED Reverse lights installed
Hmm I wonder which will be brighter and have a longer life span?
Yeah, the LED's win hands down.
Error free too.
I was surprised to find that the reverse and rear fogs are not LED stock. Now I'm thinking of upgrading the rear fogs to LED too.
Old 01-08-2016, 05:31 PM
Squalo's Avatar
I hope you will not be one of those annoying drivers that turn their rear foglight on in perfectly clear weather and BLIND following drivers. I only use mine in really bad weather and usually in the daytime. (;-)
Old 01-08-2016, 05:42 PM
markN1689's Avatar
if your being an a-hole driver and tailgating me your damn right i will be
Old 01-09-2016, 02:22 AM
sdjaime's Avatar
Link?
I got my interior LEDs from this vendor. They have excellent service. I have found that my reverse lights are way too dim backing out of my driveway. I think I might have to pick this up as well.
How was the install?
Old 01-09-2016, 03:34 AM
Storm982's Avatar
I would be interested in a link to the lights as well. Could you tell if the rear fog bulb was the same bulb as the one you replaced? Also how did you gain access to the bulb?
Old 01-09-2016, 07:02 AM
chapindad's Avatar
I am also interested in any info on where to get them and the ease of install? I live in the country and have a long dark driveway with very large and unmoving oaks, as I have discovered before, that I back out of and the audi lights are not as bright as the prius....
Old 01-09-2016, 08:32 AM
markN1689's Avatar
All you need is a flat head to wedge open the gray fabric cover. pinch the plastic clips that hold the harness. push in and twist the old bulb out. push in and twist the new bulb in. push harnes back into place and close the fabric cover. took 30 seconds.
here is the link: BaX9s Error Free Reverse LEDs fits: 2015 Audi A3 ? deAutoKey
edit ***Link fixed****
Old 01-09-2016, 08:34 AM
markN1689's Avatar
the rear fog looked a little taller than the reverse but looks like the had the same connection. I would bet 50$ that it would fit just the same
Old 01-09-2016, 11:30 AM
arU4ic's Avatar
Originally Posted by markN1689
Bad link
Old 01-09-2016, 12:33 PM
markN1689's Avatar
Originally Posted by arU4ic
Bad link
sorry here:
Quick Reply: Super Bright LED Reverse lights installed
