Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Loss of power
Old 01-07-2018, 05:34 AM
scarampow's Avatar
Default Loss of power
Hi guys, some times I drive s3 8p it feels like the turbo is not at its full potential, on the same day of feeling that, I switch it off and drive again, then it feels like a beast, my car is a 2007 model and only has 35k km on the clock, could your'll please help
Old 01-07-2018, 08:18 AM
kwekuq's Avatar
Faulty DV maybe? Do you hear it go off as if the boost is being leaked out at high rpm?
Old 01-08-2018, 01:43 AM
scarampow's Avatar
I changed the DV, I put the uprated one and I also changed the breather unit on the engine, could it be the oxygen sensor?
Old 01-08-2018, 04:44 AM
kwekuq's Avatar
Can you give some more info of what exactly happens. So you floor the throttle then it gets to a certain rpm then sort of dies out?
Old 01-15-2018, 12:05 AM
scarampow's Avatar
It drives perfectly, no cutting out, just at some times it feels very under powered, switch it off and start again, then it's like it was reborn.
Old 01-15-2018, 07:28 AM
amiram's Avatar
Do you have the option to check fault codes? What engine?
Old 01-17-2018, 07:26 PM
John535is's Avatar
Sounds like a sticky MAF or a loose vacuum hose.
Just a guess without any codes.
For the MAF you can get some MAF spray cleaner, if you decide to unplug it and take it off to clean it, when you reinstall turn the ignition on but not start. The maf should go through a re-commissioning set up, full open, full close a couple of times. After it stops then it should be good to start the engine.
A loose vacuum would produce a similar feel to a faulty DV, which you were on that path since you changed the DV. Just a thought.
Old 01-22-2018, 02:31 AM
scarampow's Avatar
Thanks alot, I'm gonna try that
Old 04-16-2022, 11:42 PM
htikan's Avatar
Default Similar issue
Hey man, just wondering if you ever got to the bottom of this as I'm having a similar issue
ssnsteamboat
03-13-2014 06:27 AM
gregory_v
12v V6 Discussion
12-25-2007 12:42 PM
Guilty
09-02-2005 05:15 AM
BSCA4
01-26-2004 11:25 AM
Quick Reply: Loss of power
