garage door opener
garage door opener
Just bought a new 2018 Audi A5 coupe , but can not use the garage door opener . It showed me on the display has been program successfully , but still can not open the garage door !
And I used the same process on my 2018 A4 , it works !
Please let me know how I can use the garage door opner on my A5 ?
I'd read the manual, just because they're both the same year and Audi doesn't mean the process is the same. Also if the garage door uses a "rolling code" which most late model ones do they can be finicky. Try again.
If your garage door opener has rolling codes, you will need to synchronize it after it is programmed. This is covered on page 45 in th manual. I struggle with this for hours and finally got it to work.
I got mine programmed after hours of frustration by pulling the Side Assist fuse as recommended in the forum, program the garage door opener, and then re-install the fuse.
https://www.audiworld.com/forums/aud.../#post25217609
Wild Turkey
12-08-2020 01:55 PM
einsgruber
Canadian Discussion
11-28-2008 02:45 PM
YumyJager
07-01-2004 01:35 AM
