How to unplug exhaust valve
Hi
I recently got this Audi A5 sportback 2019
The car is very quiet and I’d like to open the exhaust pressure valve, the problem is I have no idea how to do it. Would someone be kind enough to explain how do I open the exhaust pressure valve on this car?
thanks in advance
thanks in advance
MMI has settings that will let you make the car noisier. If that is not sufficient get a OBD 11 gizmo and set the Soundakator to the highest.
If that is still not sufficient get hearing aids turn the volume to MAX. Last measure straight pipe from exhaust manifold. )
Are you talking about the exhaust valves by the mufflers? If so, the A5 doesn't have any. If you need louder exhaust you will have to get a new exhaust system or modify your existing one (like getting new downpipes, cutting out resonators and/or mufflers).
thanks.
this is my first Audi. I’m used to bmw
messerschmiTT
03-28-2008 11:05 AM
Jeff Vader - boscoj
02-24-2005 11:38 AM
