19's on 09 A5
19's on 09 A5
Hey guys,
Nubile to the forum here. I have an 09 A5 3.2 coupe with 18's on it. I want to put the Audi 5 spoke 19's on it. Does anyone know if there are any issues? This is a non S-line model....
Appreciate your help!
There are basically 5 dimensions to consider when it comes to wheels. Diameter, width, bolt pattern, center bore and offset. For more information on these, go to Tire Rack website read more about them.
Also don't forget the center bore diamater - our cars require 66mm center bore. A wheel with a larger center bore may work if you use mounting adapters, but a wheel with a smaller center bore can't be used unless it goes through an expensive boring process (which depending on the wheel may not even be possible).
BlackOptic
A4 (B8 Platform) Discussion
04-08-2011 08:04 AM
elwookie
14
05-02-2006 10:11 PM
osuidoc
Audi allroad
03-26-2005 08:22 PM
Sinsere
07-23-2003 09:22 AM
