2013 to 2017 (FL) B8.5 Audi A5 and S5 - Recommended Tire Pressures
2008 to 2017 (FL) B8.5 Audi A5 and S5 - Recommended Tire Pressures
Update 1 - Added tire pressures for 2009 to 2012MY A5 and S5 models (North America). Added 2012 to 2017MY Audi A5 tire pressures (AUSTRALIA).
Update 2 (2016-Oct-24): Added Tire pressures for 2013 - 2017 A5 and S5 Cabrio models (North America).
__________________________________________________ __________________________________________________ ______________________________
I have noticed that a lot of B8/B8.5 A5 and S5 owners are clueless on the recommended tire pressures for their vehicles. Worse, they forget to look for the information in the Owners Manual.
Note: What is shown on the tire label on the B-pillar (driver door jamb) are maximum load tire pressures when the vehicle is fully-loaded most of the time. Fully loaded means more than 2 front passengers most of the time.
IMPORTANT: Always reset the TPMS system after you alter (add or reduce) the tire pressure for any reason (e.g., new tires) to prevent the system from giving you a false alert.
FOR NORTH AMERICAN MODELS ONLY
2009 to 2012 B8 Audi A5 and S5 models.
2013 TO 2017 B8.5 Audi A5 and S5 models.
(Source: Page 217 of the Owners Manual)
2013 TO 2017 B8.5 Audi A5 and S5 CABRIOLET models.
(Source: courtesy of kmarei. Taken from Owners Manual)
FOR AUSTRALIA:
2012 to 2016 (FL) Audi A5 2.0L TFSI Engine
(Courtesy of julianwhitta)
Note 1: Normal load is defined as having up to 2 front occupants in the car most of the time.
Note 2: Full load is defined as having more than 2 occupants in the car most of the time.
Source: Page 296 of the 2009 Audi A5 Owners Manual
Audi A5 with 2.0 4-cyl. Engine:
225/60 R17 94H All-season
Normal load (F/R): 32/29 psi
Max. Load (F/R): 33/33 psi
245/45 R17 96H All-season
Normal Load (F/R): 32/29 psi
255/35 R19 96Y XL High-Performance
Max. Load (F/R): 32/32 psi
265/30 ZR20 94Y High-Performance
Normal Load (F/R): 35/32 psi
Max. Load (F/R): 36/36 psi
Audi A5 with 8-cyl. 3.2L Engine:
225/60 R17 94H All-Season
Normal Load (F/R): 33/29 psi
Max. Load (F/R): 35/33 psi
245/45 R17 95H All-season
245/40 R18 93H All-season
255/35 R19 96Y High-Performance
Normal Load (F/R): 32/32 psi
Max. Load (F/R): 33/32 psi
265/30 ZR20 94Y XL High-Performance
Normal Load (F/R): 39/38 psi
Max. Load (F/R): 42/41 psi
The following was taken from Page 250 of the 2012 Audi S5 Owners Manual:
Audi S5 with 4.2L, 8-cyl. Engine:
245/40 R18 93Y High-Performance
Normal Load (F/R): 38/32 psi
Max. Load (F/R): 41/38 psi
265/30 R20 94Y High-Performance
A5 with the 2.0L 4-cyl. Gasoline Engine with:
225/50 R17 94H All-season Tires:
Normal load (F/R psi): 32/29
Max. Load (F/R psi): 33/33
245/45 R17 95H All-season Tires:
245/40 R18 93H All-Season Tires:
Normal load (F/R psi): 33/29
Max. Load (F/R psi): 35/35
255/35 R19 96Y High Performance Tires:
Normal load (F/R psi): 32/32
S5 with the 3.0L 6-cyl. Gasoline Engine with:
245/40 R18 93H All-season Tires:
Normal load (F/R psi): 36/30
Max. Load (F/R psi): 39/36
245/40 R18 93Y High-performance Tires:
Normal load (F/R psi): 38/32
Max. Load (F/R psi): 41/38
A5 CABRIOLET with the 2.0L 4-cyl. Gasoline Engine with:
Normal load (F/R psi): 33/30 psi
Max. Load (F/R psi): 36/39
Max. Load (F/R psi): 35/38
Normal load (F/R psi): 35/32
Max. Load (F/R psi): 38/41
S5 CABRIOLETwith the 3.0L 6-cyl. Gasoline Engine with:
Normal load (F/R psi): 39/35
Max. Load (F/R psi): 42/44
225/50 R17 94Y
225/50 R17 94H M+S
245/45 R17 95Y
Max. Load (F/R): 35/35 psi
245/40 R18 93Y
255/35 R19 96Y XL
225/50 R17 98V XL M+S
245/40 R18 97V XL M+S
265/30 R20 94Y XL
Normal Load (F/R): 36/32 psi
Max. Load (F/R): 39/39 psi
225/50 R17 94H M+S
245/45 R17 95Y
245/40 R18 93Y
255/35 R19 96Y XL
265/30 R20 94Y XL
2012: Page 250.
2013: Page 231. Page 238 does not contain any tire pressure info.
Not sure why your 2013 S5 manual quotes much higher PSI values. I looked at the manuals through the Audi Online Manuals website.
Ultimate Keyboard Warrior
Force-1, I just looked at the Owners Manual for the 2012 and 2013 Audi S5 and the tire pressures I quoted are valid for both models.
2012: Page 250.
Not sure why your 2013 S5 manual quotes much higher PSI values. The looked at the manuals through the Audi Online Manuals website.
2012: Page 250.
The page 238 I'm referring to is the manual posted at Audi website.
Audi Online Owner's Manual
The numbers you posted caught my eye as I just traded in my 2013 S5 for a 2017 S5, and after 4 years of ownership I had the pressures memorized for the 2013.
Force-1, I now know that the tire presssures you mentioned are for the S5 cab. Someone in AZ posted the tire pressures for it and they match the values you quoted.
My 2017 came with 20" OEM wheels, and unfortunately the manual does not list TP for these tires.
The factory tire recommended pressures are located on the driver side door seal on a sticker. As you are getting out look to the left.. just below the door latch
It must be a requirement because every vehicle in the U.S. they are listed there.
For North America, the B-Pillar door jamb stickers only publish the maximum load tire pressures. For normal load tire pressures, they are usually found in the owners manual but not for the 20" wheels that are part of the Black Optics Plus package for 2017.
