92 Top Tier vs 93 non-top
This is a companion post to the one I started relating to carbon build-up. My tech told me that the winter blend we get here in Maine gets a high % of corn/ethanol and that does not burn as cleanly as the summer blend. Hence, carbon buildup.
I began using Mobil premium (92) when I got my '09 S5 last year. I got a great deal on gas rebate (15 cents pg). When that went away I went looking for new gas. The only 93 octane in Maine is Citgo so I started with that. Now that I am getting some carbon in the cylinders, I am wondering if I should go back too Mobil or Shell even though it has less octane and costs more. Or keep using the Citgo 93 and use a fuel additive more frequently.
Ix
Ix
Ix
Ix
Shell is V-Power here and Optimax in Europe. BP is Invigorate here and Ultimate in the UK. Supermarket here could be Costco, Sam's club, BJ's or hundreds of others.
The wife and I swear by Shell's V-Power. Here is a video. Made in the UK, but still very U.S. relevent.
5th Gear - High Octane Fuels - YouTube
DHS - you mention Top Tier in the subject of your post, so you know that Audi recommends use of Top Tier fuel suppliers only, as these have higher levels of detergents than non-Top Tier. These detergents can help keep fuel injectors clean, but this has nothing to do with the problem of carbon buldup on the backside of the intake valves. The gas you use has nothing to do with that issue at all, because the back of the intake valves in Audi's DFI engine never comes in contact with gasoline. So if you're wondering how the choice of gas and/or additives can help mitigate carbon buildup on the valves - it can't.
Unless your engine is specifically tuned for 93 octane gas there is no advantage to using it over 91 octane. Just stick to Top Tier brands, and use 91 octane to save money.
Said recommendation (wanted to check for myself ):
http://www.audiusa.com/content/dam/a...l-Brochure.pdf
Cheers.
quattro20v
Audi Original "S" Cars
14
01-07-2008 10:19 AM
Bolo
12
05-26-2005 07:30 AM
