Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Check Engine Light just came on
Old 12-09-2015, 02:51 PM
09S5's Avatar
Default Check Engine Light just came on
2009 S5
Car has 50k miles
2 weeks ago changed all spark plugs car was running fine .
Today added a bottle of sea foam to the tank .
Got fuel also.
And now check engine light on.
I'm thinking gas cap?
Anybody else ???
Old 12-09-2015, 02:52 PM
09S5's Avatar
car runs fine on highway.
Old 12-09-2015, 06:47 PM
SloopJohnB@mac.com's Avatar
Default AAAAAANNNND, what engine codes have you pulled?
So the CEL light is on. Doesn't mean JACK unless you have a code. If you have to ask how to pull the codes, you haven't or can't read and you should just take it to the dealer and BOHICA.
Old 12-09-2015, 11:16 PM
09S5's Avatar
Code is p0421.
09S5's Avatar
I cleared it out to see if it comes back.
Old 12-10-2015, 03:22 AM
uberwgn's Avatar
I would run all the additive out. Clear the code again, if necessary. Continue driving and see if the codes re-appears.
Old 12-10-2015, 03:26 AM
09S5's Avatar
Uberwgn thanks for the information.
I purchase a code reader from autozone for about $ 80. I was surprise it worked on the Audi.
I was under the impression I needed a VAG-COM or Audi tools
Old 12-10-2015, 03:33 AM
uberwgn's Avatar
By mandate, a code reader should be able to read any car sold in the USA. Problem is, the information (codes) they return is typically less specific than the info passed back by VCDS. I guess it would be interesting to see what info the VCDS system passed back in comparison...
For now, I'd just drive the car and not worry about it unless the code re-appears.
Old 12-10-2015, 03:37 AM
09S5's Avatar
What does this means???
Old 12-10-2015, 03:38 AM
09S5's Avatar
o2 sensor?
driver side before the c.c.?
Quick Reply: Check Engine Light just came on
